Tire question
Old Apr 13, 2006 | 12:44 AM
CrewCab's Avatar
Default Tire question
Just curious to know how much air pressure you guys run in your tires? Also my rear tires are 22x10x10 which look nice and wide off the rim but when mounted and air put in the blow up like a balloon. What other size could I use that would give me a wide track instead of a tall narrow tire?
Old Apr 15, 2006 | 12:27 AM
socaltoyman's Avatar
I run about 10 pounds of pressure on the chinese quads and it really makes for a softer ride. I am using only the stock front and rear tires so I could not tell you anything about the size tires your looking for.
Old Apr 15, 2006 | 08:45 AM
mconner's Avatar
I usually run 5 to 7 pounds in the rears - depending on what were riding on. If you want wider an 11 width will make a big difference. try dropping a few lbs first and see if that works better if you still want more on the ground go wider.
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
