Yamoto 110 shock help!!!!
does anyone have a replacement shock Idea for the Yamoto 110cc. Front and back. I flipped the front tires and it seemed a little better, but I would still like to soften it up. But the rear with the shock straight up and down, it's really stiff. Is there a softer spring I could use?? Any help woul be great!!
If it is the single a arm front then John at Raceway can get a suspension upgrade from Jetmoto that replaces the front a arms, tie rods, and shocks. This makes the front wider and the suspension soft.
I got one of the suspension kits to put on my Yamoto 150. The a-arms dont fit the 150 but may fit the 110, Im not sure. The front shocks are about 1" longer than stock and put the front wheels at a pretty sharp angle. On the right quad they would be perfect for some one under approx 125 lbs. They are sprung much softer than stock. The rear is much softer than stock too. If your a fairly big guy, lets say over 175 lbs, the shocks will be to soft.
Thanks for the help!! What is the cost for the supp. upgrade kit if you don't mind me asking? Is this the rear also? I just took the springs and put them on my bench grinder and worked them over and over until they softened up!! A local spring shop told me about that trick. It worked great for the back, but the front is still a joke!!
kbazzy
Sep 26, 2015 11:26 AM
