Broken flag mount
Old May 15, 2006 | 09:04 PM
dmoell's Avatar
Default Broken flag mount
ACK!!!
The flag mount on the Kazuma 110 is really cheesy, our's is bent and about to break off. They could have used something thicker than 1/32 inch steel... <grrrr>
Since the grab bar is welded to the frame what to do?
Has anyone seen flag mounts that bolt/clamp onto a frame?
thank you
Old May 16, 2006 | 11:21 AM
solareclipse2's Avatar
I've seen them on ebay, I think raceway sells them too. Can you drill a hole in the grab bar and mount your flag in that somehow?
Old May 16, 2006 | 12:04 PM
dmoell's Avatar
OK thanks I'll look on ebay and raceway.
The grab bar is thinner than a marker, just not thick enough to drill into.
Have to rig up something that will clamp on the bar I guess.
Or mounts to the frame somehow.
I wish the grab bar could be taken off and replaced with aftermarket.
Old May 17, 2006 | 08:29 AM
mconner's Avatar
Ask all your friends if they know anyone with a welder .If you can't find anyone talk to any business that welds. If you do the prep - cut off the old one get a small piece of steel you might get them to zap it on for free or very little charge. drill the hole after it's welded. Its worth a shot, and would be alot cheaper.
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
chewy78
Sep 8, 2015 10:37 AM
toonces
Sep 5, 2015 01:14 PM
