redcat 150 wont keep running
Old May 16, 2006 | 11:45 PM
hoytultratec's Avatar
Default redcat 150 wont keep running
my wifes redcat 150 wont run heres whats going on,
drove it around the land sat it ran great just a slight hesitation no big deal, so i oiled the filter, did not soak it,
started it up was running then it died, couldnt get it started, took carb apart cleaned it put it back together fired right up, it was idling a little low so i tried to adjust the carb, it idled down then died cant get it to start again.
does anyone have a starting point for the air mixture screw?
does anyone know whats up with thing?
im not having good luck with the chinease atvs, have a falcon 250 havent even drove it yet been waiting for parts for a month[ waterpump].
need help
thanks hoyt
Old May 17, 2006 | 04:37 PM
i took the carb off cleaned meaning took jets out sprayed it all out, wasnt even dirty, emptied out tank meaning cleaned tank out, changed fuel filter too a better one, put it together, fired right up, got it idling perfect. now when i give it gas it goes good to about 5 mph when i hammer on it it just bogs out, the carb is clean, new fuel filter,gas is good, im getting pi$$ed.
this all started when i oiled the filter, it looks like a k n filter with a sleeve on it, is it the oil restricting the air flow?
oh yeah put in a ngk plug too.
thanks
hoyt
Old May 17, 2006 | 05:01 PM
took the airfilter off ran great around the yard has power again guess i need a real filter, ran better before i oiled it go figure.
Old May 18, 2006 | 09:18 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
That is pretty amazing hoytultratec. I am wondering what kind of oil you oiled the filter with? And welcome to the forum too! [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 18, 2006 | 07:16 PM
k and n recharge kit is what i bought, didnt soak it light even coat of oil can hardly suck air air thru it by mouth, bought a uni filter for it see what happens when it gets here.
Old Jul 23, 2006 | 11:48 PM
mike50's Avatar
what after market filter can i use for the redcat 150? thanks mike.
Old Jul 24, 2006 | 06:03 PM
uni filter
Old Jul 24, 2006 | 10:09 PM
mike50's Avatar
did you oil the paper filter or the outer sock? the outer sock should be oiled with 10w-40 oil. the paper filter is going to get blocked if you oil it. and the starting point for the air screw is 2 turns out.
Old Jul 31, 2006 | 09:45 PM
i oiled the filter just like a k and n filter thats what the problem was clogged filter i used the right oil, i just put a uni filter on it, and fixed the problem.
Old Aug 1, 2006 | 10:40 PM
atvmike92's Avatar
Mine wasnt idling and I found out it was the spark plug. The 150s seem to have a lot of idling
problems.
supermanotorious
Mar 12, 2021 11:02 PM
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
