Kazuma 50?
Old Aug 1, 2006 | 11:24 AM
tkbayes's Avatar
Default Kazuma 50?
I have a Kazuma 50, and it is very hard to get started. once it running for 30 min it seems to be fine. any suggestions?
Old Aug 1, 2006 | 10:18 PM
2manytoys's Avatar
Default Kazuma 50?
How long have you had the 50? A few things that will make it hard to start is a dirty airfilter, valves need adjustment or carb needs to be cleaned. The most common problem with them is the valves needing adjustment.
Old Aug 2, 2006 | 06:43 PM
tkbayes's Avatar
Default Kazuma 50?
It has been that way since we bought it. it has about 10 hours of run time. would it be the idle that needs to be adjusted?
Old Aug 2, 2006 | 08:37 PM
2manytoys's Avatar
Default Kazuma 50?
I know with out meerkat I dont choke it all teh way and it starts fine. The idle did need to be turned up a little to keep it running. What I do is try to start it choked and slowly open it up till it starts. There is a sweet spot for the choke. Once running I turned up the idle till it just starts to creep then turn it back a little. It has started great every time.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
