Jetmoto 150 final gear oil fill location
Old Jun 28, 2006 | 10:50 PM
GNXGuy's Avatar
Default Jetmoto 150 final gear oil fill
Changed the oil to 10-30 now want to change the final gear oil.
Found the final gear oil drain plug but no dipstick or fill hole as the manual states.
Want to get the break in oil out and get some 80- 90 in there.
Joe
Old Jun 30, 2006 | 09:25 AM
billl2099's Avatar
Default Jetmoto 150 final gear oil fill location
their's 3 places that the oil needs to be changed, one is the engine oil, second is the cvt trans oil and the third is the reverse gear box oil, the cvt trans and the reverse gear box both uses 80-90 gear oil, the cvt trans oil you need to remove the cover to change that oil and the plugs are next to the clutch assy. the reverse gear box oil their's a drain plug on the bottom and to fill you use remove the fitting on top of the gear box that holds the over flow vent and use that
Old Jun 30, 2006 | 09:59 AM
GNXGuy's Avatar
Thanks Bill,
Kinda what I figured, but totally different than what the manual says.
joe
Old Jun 30, 2006 | 04:16 PM
billl2099's Avatar
woop's i was thinking 250 on the cvt gear oil change, on the 150 they have a drain plug on the bottom towards the back, look you're see it, to fill their' another bolt that needs to be taken out and the oil pump in and darn if i remember if it's on the inside of the cvt cover or not, it's been almost 2 years since i did it,sorry for the misinformation
Old Jul 2, 2006 | 04:33 PM
billl2099's Avatar
ok i just look at the service manual, you don't remove the cvt cover, theirs a fill bolt on the aft side of the cvt cover, its almost center ,it also states 80-90 gear oil, you're need a gear oil pump and fill until gear oil starts to drain back out of the hole then reinstall bolt.
ScopeZ_
Jul 28, 2015 01:44 AM
black_thunder
Jul 26, 2015 09:23 PM
kdg723
Jul 25, 2015 01:20 PM
rcappie4
Jul 10, 2015 04:54 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
