rear brakes problem/sprocket placement
Old Aug 28, 2006 | 11:59 PM
steestar's Avatar
Default rear brakes problem/sprocket placement
on my JM200, the rear brakes make a really loud noise when i jam on them. it still rolls and everything in nuetral but im wondereing if this is a problem. also, the reason my chain always falls off if cause that sprokets dont line up. the back sproket is placed slightly to the right. is this the same on anyone elses quad?
Old Sep 11, 2006 | 03:43 PM
AFROracing's Avatar
sounds like the rear axle is off center, or it is loose. Having problems with the brakes and the chain are leading me to believe this. Lift up the rear and see if the axle carrier has play in it, it's possible the bearing are out there or maybe it's just loose..
later,
Chad
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
timster911
Jul 13, 2015 01:57 PM
