I'm going to be testing Jetmoto 125 and 150 Hop Up Kits!!
They are pretty lean stock. Most likely to pass the CARB test's. They would probubly be perfect for your elevtion.
Mywifesquad,just bought this kit.Can you give me any help putting all together.you said something about the carb spring ect.are there any instructons.any help would be great
<div class="FTQUOTE"><begin quote>Originally posted by: setters
Mywifesquad,just bought this kit.Can you give me any help putting all together.you said something about the carb spring ect.are there any instructons.any help would be great</end quote></div>
It doesnt come with any instructions setters. If you want to PM me your ph number I could talk you thru it.
#15
I just had the dealer put the exhaust and carb upgrade on my 125. It is a good improvement, but I can tell it is being starved for air. He didn't mention anything about Jetmoto having an upgraded air filter. I was thinking I would just get a universal K&N cone shape with a 1.562" flange and mount it directly to the carb as I ride mostly in the sand. I am hoping it won't need to be rejetted, but it probably will. What kind of air filter upgrade are you talking about that comes in the kit?
#16
Hi Dfru. The Jetmot0 125 upgrade kit should come with a foam air filter. (at least the one I got did). Its like a Uni with a coarse foam wrap and it mounts directly to the carb. If your still breathing thru the stock air box your missing out. Now that i think about it...the new air filter is to big for the stock carb. Im wondering how they got the new carb hooked up to the stock snorkel tube?
#17
Yes Dfru we and Jetmoto has an upgrade filter:
Jetmoto Air Filter
Jetmoto Air Filter
#18
<div class="FTQUOTE"><begin quote>Originally posted by: RacewayATV
Yes Dfru we and Jetmoto have an upgrade filter:
Jetmoto Air Filter </end quote></div>
Thats the one I have. [img]i/expressions/face-icon-small-wink.gif[/img]
#19
Ok, well I wasnt offered an "upgrade kit" Just a Mikuni carb for $69 and pipe for $125. I also had pink front and rear plastics put on and left the nose piece and gas tank black. It looks awesome, and when my 5 year old son grows into it he will have new black plastics! I will post pictures soon. This leads me to another question. My 125cc has the single headlight on the nosepiece like the 150, the pics on your website have the "cat eyes" headlights like the 110s my dealer has?
#20
Ok looking for some help with these up grades.Mywifesquad i called and left a message.Put the exhaust on everything ok.Put the carb on some far ok.Now the problem,they sent me a new black in color intake pipe they say you need.it is very short and if you take the old one off and put the new one on it wont let the carb pull up.The carb is resting on the engine.This does not seem right.You cant add this to the old becuase it would turn the carb side ways.Cant see how i can use this?Help not sure what to do.
