parts will be yere soon!!!!!!!!!!!!!!!!!! hopefully
Old Jun 12, 2007 | 05:09 PM
jetmotoracer's Avatar
Default parts will be yere soon!!!!!!!!!!!!!!!!!! hopefully
i need info on how to rejet my carb on my 07 250it would be a great help...and by the way how far should the mixture screw be turned out
Old Jun 13, 2007 | 06:23 PM
pimpsmurf's Avatar
You havbe to take the carb out. It's two bolts and one has a nut on it. Remember which is which.
Then you have a couple bolts to which allow the carb to come appart. It's very easy and only goes back together one way (so far as I could tell.)
Then there are two little jets that you unscrew and replace with the new ones. They are little brass things. You can do it with a screwdriver and a set of plyers.
I'm not messing with you when I tell you this is going to take 10 minutes and there really isn't a way to screw it up unless you get dirt in the carb. Also, don't over tighten the jets. Just screw them in until they are good and snug. Nothing should require much force to do this.
the sprocket is 4 bolts (2 on the cover, 2 on the sprocket.) Pay attention how it comes apart so it will go back together easily. This is also a 10-15 minute job.
-JNY
Old Jun 13, 2007 | 06:46 PM
thanks!!!!!!!!......do i have to drain the carb or something before i take it off i know that you have to shut off the gass...and how far should the mix screw be out
Old Jun 13, 2007 | 10:24 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
<div class="FTQUOTE"><begin quote>Originally posted by: jetmotoracer
thanks!!!!!!!!......do i have to drain the carb or something before i take it off i know that you have to shut off the gass...and how far should the mix screw be out</end quote></div>
The carb will drain most of its gas when you turn it on its side. Have a rag and or a drain pan to catch the gas. Please do this in a well ventilated area, not in a closed garage or basement. And definitely not near a water heater. Start with the mixture screw out 1 3/4 turns from bottoming. Dont turn the screw in hard like your tightening it, just turn it lightly until it stops. Count the turns on the way out until you get to 1 3/4.
Old Jun 14, 2007 | 09:09 AM
pimpsmurf's Avatar
Mine is only 1-1/4 to 1-1/2 turns out. I'm still running rich, but I'm starting to think more and more that my main jet is too big.
-JNY
Old Jun 14, 2007 | 04:04 PM
do i have to flip it on its side?????? because then wont i have to drain the loil and sutch cant i just take the carb out??????? and leav the bike right side up???? and does this mean i will burn more fule when i re jet????????
Old Jun 14, 2007 | 04:19 PM
KTM Patrol
Former Chinese POW!
and does this mean i will burn more fule when i re jet????????</end quote></div>
No
OK
Yes
a very small amount more than now. you wont even notice.
pimpsmurf, the fuel screw and the main jet do not affect each other. The main jet is for 3/4 to wide open and fuel screw/pilot jet are for idle to 1/4 throttle.
which main jet and pilot jet are you usuing now?
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
