got my shocks/ stearin geometry all set for where i ride..its so perifict....sorta
Old Jun 28, 2007 | 09:24 PM
jetmotoracer's Avatar
Default got my shocks/ stearin geometry all set for where i ride..its so perifict....sorta
i just got both new shocks on and ajusted the tie rods... my jm is prerice for wnere i ride now... where i ride......( i usaly ride around my house witch happens to be 17 acers of woods and it has about 8 trails... but they are long and all intrconect... the one far back trail is hard for it tho but it can still make it ...... the one trail floods when it rains....and gets about maby 1 foot of water...thats for u (pimpsmerf) and i have railroad tracks reight behind it and a long dirt road to...... to drag race....and off of that some more trails...well travled trales by others and a cupple big pits reight off those trails so they all inter conect.... the railroadtrcks...road...other trails...and pits... its so great.....but the pits they chase u out of with trucks etc..... i dont relly go in that one tho
Old Jun 28, 2007 | 09:34 PM
pimpsmurf's Avatar
Sounds like you have the setup man!
I have some great places to ride also, but when it doesn't rain (rains almost everyday in the summer) the roads turn to silt. It bogs down the engine pretty bad. When I get my rear sprocket it should be easy. I can't decide on 48 or 50 teeth. I'll bet that, with the snorkle, I can use a 48 tooth and be great, but I'm worried I'm going to have to get a new needle. It wants to run rich at 25% throttle with the 128 in, but it looks to be right on the top. Wow, from a 107.5 to a 128 with $12 worth of ABS and a $13 radiator hose. I'll bet it makes a ton of peak power now, but I'm worried about valves. I'm going to take it to the ATV guru and let him tune the carb and adjust the valves. I don't need it until I get the new sprocket anyway. It's way too hard on the clutch ATM. The 25" tires were a bad choise. I should have stuck with 22-23", or 24x7x12s all around. =)
It looks pretty crazy with these big *** tires on the back though! =)
-JNY
Old Jun 28, 2007 | 09:41 PM
lol.... ys it bad for it to run rich..isnt it better for it to run lean...and would u turn the mixture screw out or in when i get the bigger jets??
Old Jun 28, 2007 | 10:12 PM
pimpsmurf's Avatar
Lean will burn a piston
Running rich will foul spark plugs
Spark plugs are cheaper
I got a heiku! =)
Anyway, when you get the new jets, please let me know what the stock and replacement sizes are. They have a number printed on them, but they can be hard to read sometimes. I'm wondering if I need a bigger pilot jet with the snorkle, but I keep forgetting to check mine. I'm going to use the next 2 weeks, while I'm waiting on a sprocket, to take all the body panels off and secure/insulate all the wiring. My fuse keeps coming unpluged, and I want to get it waterproof. I guess this is a good of a time as any to run all my vent cables and replace the rubber hoses. I was also thinking about going ahead and getting the spacers cut so I can use these tapered bearings.
-JNY
Old Jun 28, 2007 | 11:05 PM
ill let u know when i gewt the new ones i dont feel like takein it apar now
Old Jun 28, 2007 | 11:21 PM
pimpsmurf's Avatar
Yeah, no worries. I need the numbers off the new ones more than the stock anyway. =)
I've taken my carb apart 8-9 times today, and every time it was a pain, so I know what you mean.
Thanks big time!
-JNY
klink
Jan 30, 2006 01:43 PM
Hightower
Sep 12, 2004 09:12 PM
fourlix
Aug 18, 2001 10:24 AM
54warrior
Dec 22, 2000 06:10 PM
