jetmoto 150 carb / gas leak
Old Jul 6, 2007 | 09:10 AM
kyjetmoto's Avatar
Default jetmoto 150 carb / gas leak
my son has a 07 JM 150- while setting still/ idling or engine off and parked - gas pours from the carb overflow tube- i havent tweaked the carb that much- other than getting the JM to idle smoothly-
this is a pain in the a**- anyone have a similar problem ?
i also have a few other pains but ill deal with them one at a time---------
Old Jul 6, 2007 | 09:50 AM
outofline's Avatar
One of my 07 150's did flow gas out also. I had to readjust the Float in the carb which is not too hard to do and you can even do it with out removing the carb. Just undo the two nuts that hold it to the intake pipe. Rotate the carb to the Left side (if memory servers) then remove the three screws that hold the bowl on. You adjust the float by slightly bending the metal tab that the Needle rests on. Just don't lose any parts and inspect carefully how it goes together before removing the float. Also you want to make sure there is a Vent hole in the Gas cap Rubber piece, if it's not drilled through then do it.
Any other help just ask, I have had my two 150's for a few months now. You may want to cut away at the steering stop also to increase the turning radius! See the "Mod and Repair" page on my site!
My Site
Old Jul 6, 2007 | 04:36 PM
Luv2sled's Avatar
I've not had that problem yet....what other problems are you having?
Old Jul 6, 2007 | 07:53 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum kyjetmoto ! [img]i/expressions/face-icon-small-smile.gif[/img]
If the 150 is new, some of them can leak gas for the first 1/2 hour or so. If its been longer than that, outofline gave some great advice on how to fix it.
Old Jul 6, 2007 | 08:02 PM
outofline's Avatar
The 150's have been a pretty good little quad and I have been quite impressed with the power even pulling my 235lbs around. They have climbed anything I have attempted so far. The only little things are the turning radius is way bad from the factory and needs the Mod. The muffles rattle really bad and need some internal work to stop the arrestor part from rattling. Watch the gas tank bolts, mine have come lose and I have lost a few. Most all the Castle bolts on the front steering need to be lowered to the cotter pin, you can see in my steering mod photo how I added an extra washer to do this. Your steering will come lose and sloppy! Check all your bolts often!
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
