o no what if my oil cooler gets a big stick threw it?????
Old Jul 16, 2007 | 01:31 PM
jetmotoracer's Avatar
Default o no what if my oil cooler gets a big stick threw it?????
i was thinking u know how u try to keep sticks etc away from ur oil cooler ... if some thing where to go threw it and it started spertin oil couldnt u turn it off and dis conect the hoeses from the cooler and risde it back to ur truck or house????? because its still air cooles right????... but no won wants to replace a oil cooler....
Old Jul 16, 2007 | 03:55 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
It would be ok to disconnect the hoses and reconnect them to the engine to get you home. I wouldnt ride it like this for very long because the engine runs about 50-70 degrees cooler with the cooler.
Old Jul 16, 2007 | 04:17 PM
yea thats what i thought would happen.... i thought my quad runs hot now i cant amajin what would happen if it broke and i had to do that
Old Jul 16, 2007 | 08:44 PM
buckaroo50's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jetmotoracer
i was thinking u know how u try to keep sticks etc away from ur oil cooler ... if some thing where to go threw it and it started spertin oil couldnt u turn it off and dis conect the hoeses from the cooler and risde it back to ur truck or house????? because its still air cooles right????... but no won wants to replace a oil cooler....</end quote></div>
Yes, carry a short piece of copper tubing about 2" long, and a couple small hose clamps in your tool kit. If you make a puncture to the radiator disconnect the hoses and put the copper tubing in, clamp it and drive home slowly and stop often to let the engine cool, until you get the radiator fixed properly. You might also want to carry a little extra oil just in case you need it.
Old Jul 16, 2007 | 09:20 PM
no i was just saying in not gunna carry all that and i want to make a oil cooler gard
Old Jul 17, 2007 | 02:37 AM
pimpsmurf's Avatar
get some screening from autozone/advance auto or just about anywhere. Just cut it to fit and bolt it on. It would also be very very easy to use a much better heater core/radiator for the oil cooler. You might have to make a custom mount, but it could be much bigger and really help cool the engine.
-JNY
Old Aug 4, 2007 | 06:38 AM
outofline's Avatar
If you by-pass the oil cooler you are not going to have to drive slow and stop often to get home, that's the worst thing to do! For years I have ridden 100% air cooled motorcycles and never had to ride slow and stop often. Actually the best thing to do is go faster to get more air going passed the heat fins on the head. And stopping will only cause the motor to heat up more, it needs cool air to cool down! Remember this is an Air Cooled motor that they slapped on an Oil Cooler to drop the running temp down just a bit to help with performance and longevity of the motor and it's a selling feature over other air cooled quads that have a little worthless Computer Fan (that seems to go bad with in a few months) mounted in front of the head like you find on a lot of air cooled Chinese quads!
STLyamwar
Jul 25, 2020 04:44 AM
01ssls1
Sep 22, 2015 06:50 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
blessedn09
Aug 9, 2015 03:07 AM
metal249
Jul 24, 2015 01:00 PM
