sputtering
Old Aug 21, 2007 | 03:35 PM
jetmotoracer's Avatar
Default sputtering
today i was riding my quad and there where 6 in puddles in the trails, and then my brother took it out for a spin and he came back and said it was acting weird and i road it and when u whent to give it more throttle it would start to choke and sputter. so i thought that i might have water in the engine so would i have to drain the carb, and what else could it be?
Old Aug 21, 2007 | 05:28 PM
billl2099's Avatar
Default sputtering
water in the air filter, clean it, dry it out then reoil it
Old Aug 22, 2007 | 01:32 AM
00XJ's Avatar
Default sputtering
I found on mine if water gets in the kill switch on the handlebars it will sputter, and die. It has only happened once or twice, and once was when I washed it with a power washer. I simply blew into the switch several times to blow the water out, and it ran fine afterwards. Also you might check the wiring harness connectors under the front panel. They aren't covered very well either.
My son and I have had the quad in several creeks, deep water holes and NEVER had any water get into the carb. Surprising since it has no airbox.
Old Aug 22, 2007 | 11:04 AM
outofline's Avatar
Default sputtering
Don't oil your 250's filter as bill suggested, it's not made to oil
Old Aug 22, 2007 | 01:34 PM
00XJ's Avatar
Default sputtering
<div class="FTQUOTE"><begin quote>Originally posted by: outofline
Don't oil your 250's filter as bill suggested, it's not made to oil</end quote></div>
I agree. I oiled mine and it wouldn't run at all. I have made a foam filter cover that fits over the stock filter, and I do oil it slightly with no problems.
Old Aug 22, 2007 | 01:56 PM
billl2099's Avatar
Default sputtering
if it's made of paper then no oil, but if it's made of wire mesh, foam or fabric, then it needs to be oiled, of couse to much oil will cause will also plug the filter, so the filter needs to be spayed lightly, i use pj1 spray filter oil on both the wire mesh, foam filers, and k&n filter oil on the fabic filters, the oil catches the very fine paricals and without the oil their's no way the filter will catch these and will enter the engine and cause faster ware on the piston and cylinder.
Old Aug 22, 2007 | 11:13 PM
outofline's Avatar
Default sputtering
It's paper, no foam. do not oil!
Old Aug 23, 2007 | 02:53 PM
billl2099's Avatar
Default sputtering
if you have a paper air filter then you need to junk it and install a form (uni filter) or a better fabric filter (K&N), the paper filters are not made to be cleaned they are deposible filters. after 45 years working on m/c and atv's have never seen a paper filter on a dirt bikes or quads, so i don't know whats jetmoto's thinking is
Old Aug 23, 2007 | 03:08 PM
Default sputtering
its the same a s a k&n i think it is paper raped in wire
Old Aug 23, 2007 | 05:47 PM
billl2099's Avatar
Default sputtering
<div class="FTQUOTE"><begin quote>Originally posted by: jetmotoracer
its the same a s a k&n i think it is paper raped in wire</end quote></div>
K&N airfilters also look like paper but are a fabric filter. if dirt is embedded in the paper how are you suppose to clean it without damaging the paper? are you just hosing off the dirt, or using a air filter cleaner?
