Meerkat 50 valve adjust?
Bought it this summer and it rode great. Now it's getting hard to start and dying when my son is riding it. I first messed with the air/fuel mixture screw and idle screw. helped but did not fix the problem. So I just adjusted the valves but this is the first time doing it. I got my .003 feeler in there but after I tightened up the nut it felt loose again. Now it's really hard to start and won't stay running at all... Any help for a first timer???
I tried again and it will just turn over and that's it..... I want to make sure I'm at top dead center. There is a cover on the left side that has access to the crankshaft. Above that is a little cover and when you take that off there are some markings on it. When you turn the crank which mark is top dead center???? Or is there another way to find it out???
Hankey Pankey
05-01-2018 01:33 PM
fordfaithful21
12-07-2015 05:52 PM
Hankey Pankey
08-17-2015 05:01 PM
