kAZUMA FALCON 250 HELP
Old Dec 22, 2007 | 12:26 PM
OLDDOGNEWTRICKS's Avatar
Default kAZUMA FALCON 250 HELP
I HAVE KAZUMA 250 FALCON HARD TO START ,HAS WEAK SPARK, ANY ONE HAD THIS PROBLEM.
Old Dec 22, 2007 | 07:33 PM
outofline's Avatar
Kind of hard to tell if the spark is weak! I would bet it's a carb/choke problem as this is the main reason for most hard to starts.
Old Dec 23, 2007 | 11:24 AM
When i pull the plug and turn the motor over the spark seem weak, same with new plug.
Old Dec 23, 2007 | 10:33 PM
outofline's Avatar
How does it run when it is running? Like I said usually a hard to start problem is the carb!
Old Dec 24, 2007 | 01:06 AM
hoytultratec's Avatar
its a carb problem is it cold where you are? i own a kazuma 250 falcon 06 model brand new has about a hour on it only ridden around the yard when it gets cold it wont start i never messed with it i dont ride it dont need it want to get rid of it cheap!
hoyt
Old Dec 24, 2007 | 01:08 AM
usually you either have spark or you dont have spark.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
Aug 3, 2015 10:21 AM
painnpanic
Oct 20, 2004 06:42 PM
