Vbike 250 v4s
Old Apr 6, 2008 | 10:10 AM
  #151
Coloradotrailrider's Avatar
Default Vbike 250 v4s
Wow! 67mph on a Vbike, dang man your brave. I am still getting used to the feel of a quad, I rode a dirtbike all my life. Just zipping up my street at full throttle seems more than fast enough to me. Must be the age factor, the older you get the less chances I am willing to take. I'm knocking on fourties door this year.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 6, 2008 | 03:28 PM
  #152
ssgt tanner's Avatar
I just turned 30 all the thanges i have had to do in my life . go 70mph on the bike dos no scare me
Old Apr 7, 2008 | 01:56 PM
  #153
Hy my rear hubs keep coming loose even with the cotter key the nut keeps backing off is it ok to have play in it?
Old Apr 7, 2008 | 07:00 PM
  #154
split196's Avatar
i have seen this the problem i see is this.....
once the bolt has its hole drilled through to recieve the pin thats the problem,they are drilling the hole to high...for example if you took one of these bolts out and stood it on its head then screwed the nut down to locate the pin, the hole is actually above the nut so the nut can spin before it comes into contact with the pin....just a case of bad engineering and testing,found this out the other day when i notices my steering upright shaft was loose.this was ment to have a pin,and was ment to stop it from spinning but once the nut was tightened down the pin comes through about 3mm higher than the top of the nut.....
answer???
tighten bolt down to ATAH (as tight as hell)
Old Apr 7, 2008 | 11:22 PM
  #155
I FOUND THE WAY TO FIX PUT SOME WASHER IN FRUNT OF THE NUT SO THE HOLES LINE UP WITH THE NUT
Old Apr 7, 2008 | 11:39 PM
  #156
Sorry SSGT Tanner I didn't reply to this sooner, the washers is exactly the way I fixed mine.
Old Apr 8, 2008 | 12:25 AM
  #157
I had to sent off for my title for my vbike thay sent back a real title with engine make it sead that it is a lifan engin and the real diplacement is 229.8cc on the title.
Old Apr 8, 2008 | 03:10 AM
  #158
slydogsrus's Avatar
So it appears that Zongshen or Lifan can be the manufacturer of these 171FMM engines, well at least the 229cc spec is the same with either engine. Thanks ssgt tanner for the info, check my post on the "171FMM who makes it" as I posted some specs for our engines......................Slydog
Old Apr 8, 2008 | 12:33 PM
  #159
My title sead the engin is from lifan manufacturing china epa code gave thim the informationthe tag office told me it is in thare database
Old Apr 10, 2008 | 11:45 PM
  #160
Dos any one know what the gearing on the stok vbike is an haw to change i need
more low end power
