Well it finally broke.
Old May 26, 2008 | 12:01 AM
NJDale's Avatar
Default Well it finally broke.
Whow, close to 4" for the center hole - I'm surprised that there was enough "meat" left to drill the lug holes at 110mm apart (@ 180 degrees straight across center to center). 4" is about 102mm. Are the lug holes even on 110mm?? (about 4-5/16" center to center??) I don't think that they can be.
Maybe what they sent you was for a "250 Hunter" ??? It will be interesting to get to the bottom of it.
Old May 26, 2008 | 12:36 AM
00XJ's Avatar
Well I was off alittle...the hole is 4 1/4", and the bolt circle is about 5 5/16" on the "new" set of rims.
Old May 26, 2008 | 11:32 AM
NJDale's Avatar
00XJ - That replacement wheel CAN'T be for a JM250 Sport, MUST be for something else !!!
How WIDE is the Rim ??? If it is 10" wide -then it is for UT (Hunter)
250 Hunter Wheel Link
This is the JM250 Sport Hub
JM250 Sport Hub Link
This is the JM250 Sport Wheel
JM250 Sport Steel OEM Wheel
This is a Jetmoto Aluminum Upgrade Rear Wheel
JM250 Sport Upgrade Aluminum Rear Wheel
Hope that these help you. I had once where Danielle said "Oh, I thought that you had the Utility" - but, it got caught BEFORE anything was shipped. I think that at certain times of the year things get a little hectic at both John's and Eugene's.
Old May 26, 2008 | 01:44 PM
NJDale's Avatar
Kim, Here's an idea for you;
Tuesday morning, why don't you call Jetmoto Parts @ 650-875-9999 x 202, and order Part Number "J2548980" "OEM Rear Rim 10 Inch" for $36.99; BUT, tell them that they MUST !!!! physically check the wheel rim against Part Number "J2548475" Wheel Hub 2007 JM250 Sport (ESPECIALLY that the rim hole fits TIGHT against center mounting ring/flange on the hub) - BEFORE they ship the rim out.
This will eliminate the "seven blind men describing an elephant" syndrome.
The "Little Brown Truck" might even show up by Friday.
Good Luck
Old May 27, 2008 | 09:57 AM
  #15
RacewayATV's Avatar
00xj please give me a call. I know we sent you some rims but I am not sure why this problem was not corrected?? Call me and I will get on this ASAP for you.
John.
Old May 27, 2008 | 07:31 PM
  #16
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I got a 3.53 step on the hub. a 3.55 (edit) hole in the rim. Bolt holes are 10mm(.394) on a 110 mm bolt circle.
Old May 27, 2008 | 09:03 PM
  #17
NJDale's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mywifesquad
I got a 3.53 step on the hub. a 5.55 hole in the rim. Bolt holes are 10mm(.394) on a 110 mm bolt circle.</end quote></div>
MWQ - Don't you mean 3.55 Hole in Rim ???? The 110mm (4-5/16") bolt holes would be kinda "in space" ?????
Now - Lets see, where did I put that "Measure Stick" !!!
Old May 27, 2008 | 10:09 PM
  #18
KTM Patrol
Former Chinese POW!
<div class="FTQUOTE"><begin quote>Originally posted by: NJDale
Now - Lets see, where did I put that "Measure Stick" !!!</end quote></div>
Yah 3.55 [img]i/expressions/face-icon-small-blush.gif[/img]
nah...I, just need to type slower, I use a digital caliper most of the time.
Old May 27, 2008 | 10:14 PM
  #19
NJDale's Avatar
Yah 3.55 [img][/img]
nah...I, just need to type slower, I use a digital caliper most of the time.</end quote></div>
Yeah, Yeah, Yeah - As we get older we ALL blame it on a slip of the FINGER rather than a slip of the MIND !!!!!
Old May 27, 2008 | 11:27 PM
  #20
00XJ's Avatar
I spoke with John at Raceway, and spoke with Eugene at Jetmoto also. Problem with getting a rim that fit appears to be nothing more than miscommunication(s). I gave Eugene the dimensions of the hub, and bolt circle this afternoon and he is sending me a new rim.
