what ngk plug do I use?
Old Apr 21, 2009 | 11:10 AM
onebigzj's Avatar
Default what ngk plug do I use?
I got the redcat mpx 50. and never changed the plug and its got atleast 100 hours on it and started running goofy. and I know I have seen the crossover plug but now I cant find it. anyone remember?????? thanks
Old Apr 21, 2009 | 03:25 PM
spliffy's Avatar
NGK C7HSA Try that first, if it still does it & the carb is clean, it most likely needs a valve adjustment after that many hours. They should both be set at .004 at Top Dead Center.
Old Apr 21, 2009 | 03:28 PM
onebigzj's Avatar
is the T.D.C. marking under the valve adjust cap?
Old Apr 22, 2009 | 10:32 AM
spliffy's Avatar
No, on the left side of the engine there should be a small screw on top remove that & the one on the side the bigger screw cap & turn it over by hand with a 17mm, then just find the timing mark on the magneto & it should be at TDC by looking through the top screw cap hole you removed.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
frostphase
Aug 19, 2015 07:11 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
