carb adjustment
Old May 25, 2009 | 10:33 PM
samzr2's Avatar
Default carb adjustment
Hi,I have a 250cc Chinese Quad,all it says on it is 250 ATV,I am not sure what the brand name is but it does have Zongshen stamped on the engine cover,I am trying to adjust the carb,as the idle goes from high to very low,and is very inconsistent,I read the post about the adjustments,but my air mixture screw will not turn,I suspect it is preset at the factory,I also don't have the carb with the cap on top,all I really have access to is the idle screw,can someone please help,thanks.
Old May 26, 2009 | 09:12 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum samzr2!
Can you figure out what is keeping the fuel screw from turning? Some times its a plastic cap you can break off..Bottom line is these Chinese quads are set up very lean to pass emissions test's.. as a result they run poorly stock...I would look into getting some large jets for your carb..a larger pilot(slow) jet and main jet will work wonders.
Old May 26, 2009 | 11:36 AM
samzr2's Avatar
no there is no plastic cap to break,it seems almost like its loctited in,it is embedded in the carb bowl and just won't budge,I guess I may have to remove the carb and do as you suggest,however I am finding it very difficult to find a place that services or sells parts for these quads,would you have any suggestions,thanks for responding.............Sam.
Old May 26, 2009 | 12:10 PM
KTM Patrol
Former Chinese POW!
Thats a bummer.... Finding a place to work it might be tough. I would look for a "no name" type of motorcycle shop..or maybe even a lawn mower shop...There is s guy near me who started out working on generators, lawn mowers etc....and now is working on a lot of Chinese quads and go carts..
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
