Kazuma 110 charging problems
Hello , I'm new to this forum , and I'm hoping you can help me out . I bought my daughter a Kazuma 110 mini hummer , and it runs fine when it runs .
The problem is that after running the quad for approx 20 min , it drains all the juice out of the battery , , and if she shuts it off , she can't re-start . the battery is good , because after putting it on the charger for an hour my meter is reading 12+ VDC and holding . None of the lights are left on , and I disabled ( pulled the plug on the alarm ) I have boosted the quad with a booster box , and afetr disconeecting it does stay running with NO battery , and my meter shows no voltage on the battery wires ..
I would greatly appreciate it if anyone has any ideas as to what might be causing this. I'm at my wits end
, and I'm ready to throw this thing off a cliff someplace .
The problem is that after running the quad for approx 20 min , it drains all the juice out of the battery , , and if she shuts it off , she can't re-start . the battery is good , because after putting it on the charger for an hour my meter is reading 12+ VDC and holding . None of the lights are left on , and I disabled ( pulled the plug on the alarm ) I have boosted the quad with a booster box , and afetr disconeecting it does stay running with NO battery , and my meter shows no voltage on the battery wires .. I would greatly appreciate it if anyone has any ideas as to what might be causing this. I'm at my wits end
If you boost it with the battery dead and the engines continues to run, the charging system is working. I think you should check the battery, connections at the battery, and the starter could be drawing to many amps when hot. Good luck
Thanks for the quick reply , I'll go out and give it a try today .
Start the machine up & let it run for about 10 minutes, then find the Voltage Regualtor, it is a small 2x1 rectangle box with fins on it & usually 4 wires going to it, feel this & see if its warm... if its not, you need a new one, if it is, then you have something else going on with the charging system.
I found the regulator , and it stays cold even after 20 mins of idling. Any thing special I should know about buing a new one? Can I use any old regulator from a parts store?
They have to have the same plugin to work... I would just get one from online or a local off brand ATV dealer. Here is a link to one that should be the same as yours:
Kid ATVS Jetmoto - 70cc atv dealer For Sale free shipping
bzdok1234
30
Feb 23, 2016 01:55 PM
