250CC two wheel drive ATV- Need Help
Old Jul 14, 2009 | 01:58 PM
Sunny13's Avatar
Default 250CC two wheel drive ATV- Need Help
My son-inlaw dropped off a olive green colored ATV off last night and said he wanted me to try to get it running. There is no identifying marks on it, but it looks very close to the Yamaha Bear Tracker 250. The engine has the recoil start rope on the left side, has a reverse shift lever like the yamaha. Clutch adjustment set screw is on the right side below the dipstick. There is a fox symbol on the front and thats the only decal. Number on lower part of cyclinder jug is JSFG229CM (with cubed symbol following).
I got it running, now found out that the clutch is worn out and needs replaced, slips real bad.
Can anyone tell me who makes this? Appreciate any help
Thanks
Old Jul 14, 2009 | 04:44 PM
hoytultratec's Avatar
any way you can post a pic of the machine and especially the motor? we should beable to figure it out pretty easy.
Old Jul 14, 2009 | 05:50 PM
Sunny13's Avatar
Unknown Quad pictures are posted on the ATV Photo galleries. Not sure how to post link. See if you can view them ok. Hope this helps.
Thanks
Sunny13's Avatar
Thanks
Old Jul 14, 2009 | 05:53 PM
Sunny13's Avatar
Try this ATVConnection.com ATV Enthusiast Community - Sunny13's Album: Unknown Quad pictures
Old Jul 14, 2009 | 06:17 PM
sure looks like a yamaha clone engine, I wonder if its the same motor jetmoto uses..im doing some looking
Old Jul 14, 2009 | 06:39 PM
hey click on this link is this the same little animal as on the front of the atv ? - the christmas hat.
http://www.redcatmotors.com/
Old Jul 14, 2009 | 07:08 PM
Sunny13's Avatar
The decal on the front looks more like a red fox. I should have taken a close up photo of it.
Who do you think makes the Yamaha clone engines? I wonder if the clutch parts for Yamaha would work also, probably not that lucky. I seen some clutch plates on E-Bay for the Bear Tracker.
Old Jul 14, 2009 | 07:17 PM
I put a honda waterpump kit w/honda impeller in a honda clone motor, just be patient user Mywifesquad or someone else might be able to verify the motor better to what clone it is, as far as who makes the motor in china???? I think there are a bunch of factories that make them.
Old Jul 14, 2009 | 07:28 PM
Sunny13's Avatar
I found this website Utility ATV - Dct Motorsport Co.,Ltd It's a China company and it says it has a Yamaha engine on it. You think this might be the culprit? What do you think Hoyt?
