lion cub 90 starter issues
Old Oct 5, 2009 | 06:40 PM
lioncub's Avatar
Default lion cub 90 starter issues
the starter is turning as well as the chain but not the crank, did a weld break on the sprocket behind the flywheel/clutch?? it starts fine with the hand crank. thanks
Old Oct 10, 2009 | 10:12 PM
LynnEdwards's Avatar
Electrical Expert
I don't know anything about what engine is used in lion cub ATVs, but I'm betting you have a starter clutch like many other quad engines, and it is slipping. The starter clutch is a one way sprag clutch that allows the starter motor to turn the engine, but when the engine starts up the clutch overruns and disengages the engine from the starter. This keeps the engine from spinning up the starter motor.
Old Oct 11, 2009 | 06:15 AM
lioncub's Avatar
Thanks, I will be taking it apart today to check it out!
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
