Tao Tao ATA 110-B Brake Job
The new pads finally came in. Looking at Sawyers pics I noticed the tin retaining clip that holds the brake pads in place on mine fit real loose on the caliper where his fit snug. I straitened the tin clip and re bent it to fit better on the caliper and put it all back together. If the rain stops Ill take it for a ride. If there's no problems we'll see how long it lasts.
#18
I think I did my first brake job somewhere around 1970. It was on the family's 67 Ford Station Wagon with 4 wheel drum brakes.
OneTenCC you might be on to something there. If I'm not mistaken mid 70's GM disk brakes had a bad squeal to them so GM came up with a paste you put on the back of the inner pad to glue it to the caliper piston. I wonder if I can still find that stuff. If I do find some I wonder if would stand up to mini ATV use.
#19
Joel
oliveiracarlos
Sep 7, 2015 03:39 AM
