Muffler, Filter......and Jetting???
The best way I found (without expensive analyzers and stuff) is to read your spark plugs. If your engine isn’t running right at a certain rpm range (Hi, Mid, Low) ride the bike at that range until it starts acting up then cut the engine without letting off the throttle. Pull the spark plug and compare it to the chart at this web site http://www.dansmc.com/spark_plugs/spark_plugs_catalog.html. Make adjustments accordingly (increase or decrease the size of the appropriate jet)
I'll see if I can save the chart as a pic and post it.
I did a Hypercharger upgrade on my Volusia and didn't want to loose the gas milage that re-jetting would have caused so I started making restrictor plates from the bottom of coffee cans and reading plugs. When I got to the right size opening I made an adaptor plate out of 1/4" aluminium.
#15
Good point nimadd, good thing about 4 strokes is they handle a lean condition much better than a 2 stroke engine would. More than likely why most all 4 strokes come from the factory jetted lean, and most 2 strokes come jetted a bit rich.
#20
Pinging at its finest!! (or worst)
