Ignition Problem - Coolster 6250
Old Oct 10, 2014 | 11:37 AM
dew777's Avatar
Question Ignition Problem - Coolster 6250
I've got a Coolster 6250 which has done pretty good but now I have an ignition problem: No spark. The motor turns over but won't crank. I pulled the spark-plug and held the side against the engine-block (to ground it) and couldn't see any spark at all.
I started throwing new parts at it in wild hopes of curing it:
> New CDI
> New ignition Coil (w/spark plug cable)
> New Sparkplug
> New Contact-Coil (starter solenoid)
> New Key-switch
Still no spark.
Are there some step-by-step guidelines for trouble-shooting these karts?
And it might be something as simple as a ground-cable connection ~ what's the best way to check that it's ok??
What is the minimum voltage that I need to see across the battery terminals?
I'm at a loss to make this thing run again. . .
Thanks in advance!
Old Oct 11, 2014 | 05:30 PM
brumbear's Avatar
*Trouble Shooter Guide for NO-SPARK Chinese Engines
Old Nov 19, 2014 | 02:13 PM
chevydad6's Avatar
How does your starter seem? It could be a loose group connection I just has this issue. You have replaced all the correct parts so far in diagnosis. Check the ground on the battery, solenoid, and the the coil. I had this problem mine was ground. And then it was the starter.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
