Coolster 125 atv won't stay running more than one minute
Old Aug 1, 2016 | 01:48 PM
Ryangerhardt's Avatar
Default Coolster 125 atv won't stay running more than one minute
My son's coolster 125 atv will start and run for approximately 1 minute and then seems like it's wanting fuel
And stalls??? I've cleaned the carb twice, any ideas?
Old Aug 1, 2016 | 03:07 PM
hugemoth's Avatar
Run until it stalls, immediately turn off the petcock or clamp fuel line, loosen drain on float bowl and see how much fuel comes out.
Old Aug 1, 2016 | 03:27 PM
DirtDevil101's Avatar
Sounds like a clogged float valve passage...make sure you spray carb cleaner in the fuel inlet and watch it shoot out of the bowl...then you know it's clear...
Old Aug 30, 2016 | 10:02 AM
blaze_master's Avatar
if none of those work, I would get a new plug if it still has original.
Old Aug 31, 2016 | 09:28 AM
Zrock's Avatar
Super Quad Patrol
Does the machine have a shut off or fuel filter? They may be clogged or gummed up restricting the flow of fuel as well
Shooter71
1) Engine problems..
Sep 10, 2016 10:49 AM
Williamkwebb
Apr 17, 2016 09:45 AM
Shooter71
Apr 8, 2016 08:15 PM
Shooter71
Apr 8, 2016 08:02 PM
Kymco 450i
Feb 11, 2016 09:56 PM
