2005 Baja 300cc extreme - parts
Baja Parts Catalog | Baja Kart Parts | Baja ATV Parts Seem to be the spares supplier, but all your requirements are "no longer available." A link on this forum has the engine down as a Suzuki GN250 clone, so the carb for this may fit. If the tap is vacuum operated, you can bet it is Suzuki clone too.
If your problem is dirt, I would advise cleaning what you have, and fit an in-line filter.
baja parts catalog baja kart parts baja atv parts seem to be the spares supplier, but all your requirements are "no longer available." a link on this forum has the engine down as a suzuki gn250 clone, so the carb for this may fit. If the tap is vacuum operated, you can bet it is suzuki clone too.
If your problem is dirt, i would advise cleaning what you have, and fit an in-line filter.
Stephan Olivier
1) Engine problems..
03-06-2013 01:13 AM
