Conti 200cc quad. (CQB200) 4 gears and reverse
Old Jan 14, 2018 | 03:50 AM
Boetie's Avatar
Default Conti 200cc quad. (CQB200) 4 gears and reverse
Hi
Bought a Conti 200 quad with all cables removed,Also cable plugs removed.Where can I find a wiring diagram.It Has a 6 pin cdi not sure if it is ac or dc also no regulator found so assuming its dc.Can someone also explain how to put it in reverse gear.
Engine number167FML85800088
Frame number LHJSJM86X5B00T
Old Jan 14, 2018 | 07:26 AM
hugemoth's Avatar
Typically reverse is where 1st gear would be on a motorcycle, one click down from neutral.
Old Jan 14, 2018 | 09:56 AM
Boetie's Avatar
Default conti 200
Thanks will give it a go when its running
Boetie
Jan 23, 2018 01:34 PM
rawfish
Aug 3, 2009 11:52 PM
bestoffroad
Nov 14, 2007 12:33 PM
2Slow4U
May 30, 2006 10:28 AM
Magmagnum
Mar 21, 2004 08:47 PM
