Shaft drive
Old 11-07-2003, 03:54 AM
joebobby's Avatar
Default Shaft drive
Are the shaft drive locked up in the rear so both tires always spin? i wondered if there was a difference on 4wd and 2wd models.
Old 11-07-2003, 12:18 PM
Jerms's Avatar
Default Shaft drive
What brand and model of quad are you talking about? Most have a straight rear axle with one drive shaft driving it off of the engine whether you're in 2wd or 4wd mode. As a result, this sort of setup drives both rear tires at all times, no questions asked. I'm not sure about those with independent rear suspension (the newer Grizzlies, among a few others) but I'm pretty sure they're locked all the time. A few models (at least some older ones) have a feature that allows you to unlock the rear axle so that it acts as a differential. Very handy when you're driving in your yard so that it doesn't tear up the grass when you turn.
JC
speedbuff
13
11-11-2020 10:16 AM
NewGuy2481
10-06-2015 05:54 AM
bvolks
09-13-2015 12:57 PM
bigbear350quad
09-11-2015 12:40 PM
MikeyBoyesq
09-07-2015 10:44 PM
Quick Reply: Shaft drive
