got new ITP mudlites, but can't remove stock tire
Old Nov 10, 2003 | 08:44 PM
maddawg0517's Avatar
Default got new ITP mudlites, but can't remove stock tire
on the 2004 Grizzly, front wheels only, rears were a snap. but these front tires have 3 grown men, two pry bars, a bead breaking machine, and a can of lube scratching their heads. i think the tire is glued to the rim. we honestly can't get it off and trust me we are using brute force by way of 8 pound sledge, crowbar, etc. how in the world do you get them off??
Old Nov 10, 2003 | 09:53 PM
shadowmaker's Avatar
I saw somewhere you should leave air in the tire. 6 lbs comes to mind. I ll look and see if I can find the topic, it was on another forum.
Brad
Old Nov 11, 2003 | 12:04 AM
well, finally got it done and the bike is nasty beast with the new treads. we ended up removing one of the tires with a sawz-all by cutting it into about 20 pieces. the other one we go off using the bead breaker tool and 3 pry bars to get pressure where we needed it but they were some SOB's to get off.
after seeing how the bead breaker machine was sliding off the tire with no air in it, i see where leaving air in may help
Old Nov 11, 2003 | 01:42 AM
Kraw's Avatar
wow, the dealer had no problem removing mine. ANd it was Wal Mart!
I love my Mudlites! How do you like them so far?
Old Nov 11, 2003 | 09:52 PM
newbeatle's Avatar
the very thin stock tires can be very difficult to remove... 1st try just leaving the valve core in... if it doesn't work... leave 2-4 psi in the tires, they will normally pop right off the rim... I've never had a problem since I heard about this trick...
slowgsxr97
Mar 18, 2022 03:40 AM
baysport
Jul 23, 2015 11:37 AM
Desimation2k8
Jul 17, 2015 12:37 AM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
