HELP, how do you read tire size?
Old Jan 3, 2004 | 08:46 PM
ThrashAndCrash's Avatar
Default HELP, how do you read tire size?
How to you read the tire size? My rears SAY 22 X 11.00 - 8. I thought that ment 22" tall 11" tread pattern and a 8" wide rim. when I busted out the tape measure on it NONE of the numbers are even close??????????????? What is up?
Old Jan 3, 2004 | 09:16 PM
Come on I know some of you knowlegable guys are online tonight!
Old Jan 3, 2004 | 09:27 PM
newLTkid's Avatar
i'm not positive on the 22" but i think you got that right. i'm pretty sure that the 11" is how wide the tire is. and the 8" i know is the rim size, if you measure the rim with the tire on it just go from the edge of the rim straight across and it should be 8" or real close to it.
Old Jan 3, 2004 | 10:07 PM
The tire measures 21" tall ( new it was prob 22) ant the rim is 9"( I think the 8" is the bead size) But NOTHING even comes close to the 11" The tread is 9" wide??????????????????
Old Jan 3, 2004 | 11:39 PM
NichelsonRacing87's Avatar
tire diameter x tire width x wheel diameter. that probably doesn't come close to 11" because you probably have a wider tire on a not as wide rim.
Bratman2
Aug 6, 2022 01:42 AM
Schneider
Jul 24, 2015 05:05 PM
baysport
Jul 23, 2015 11:37 AM
ltrmc02
Jul 22, 2015 04:50 AM
rcappie4
Jul 18, 2015 07:51 AM
