mudlites
Old Feb 11, 2004 | 11:40 AM
AlaskaBoy's Avatar
Default mudlites
EarlTash, 1800 miles is quite impressive with hardly any wear. I agree with your saying, I to, hate to replace something do to premature wear. I do not know how long these MudLites will hold up but time will tell.AlaskaBoy.
Old Feb 11, 2004 | 12:07 PM
earltash's Avatar
Default mudlites
Yes i was so impressed with them i ordered another set. I went with 1 inch taller and 2 inches wider in back-with new rims.
Rears will be-26*12*12
Fronts will be-25*8*12
This is on a 300 kingquad and i think bout all it will push-HA!
I think now with these back tires i won't hardly ever use 4*4.
The 10 inches ones i got now work ok,but at times i do have to shift to 4*4.
With the kingquad the weights all in the back-its the way the engine and tranny with the transaxel set up is at.
Its not a big machine,but it gets me out there.
Also i will have a extra set to bring with me on those extended camping trips-just in case.
Check out- http://www.precisionpowersports.com/ for tires.Not sure about the shipping thing crossing the border?
Old Feb 11, 2004 | 12:13 PM
AlaskaBoy's Avatar
Default mudlites
I had a King Quad for 9 years and when I put on the Bear Claws I found that I did not have to use four wheel drive all that often.AlaskaBoy.
Old Feb 11, 2004 | 12:17 PM
lafngas's Avatar
Default mudlites
earltash, how the ridding around Rockland? I drive a gasoline and oil tanker and I haul down your way all the time. I noticed some trails on the side of the road. I recently hurt my leg out ice fishing a couple of weekends ago so I am down and out for awhile so I won't be doing any ridding soon but I would like to make it down that way to look around!
Old Feb 11, 2004 | 04:35 PM
  #15
earltash's Avatar
Default mudlites
There are quite alot of places to ride.Polelines, old logging roads etc. There are a lot of places also posted. But i find enough places local to keep my riding all the time without getting to bored.
Old Feb 11, 2004 | 04:37 PM
  #16
earltash's Avatar
Default mudlites
The kingquads are a great machine. They don't have all that power where you touch the gas and start spinning-you generaly just go. With that low range also the machine does real well. Plus all the weight is on those back tires-that sure helps.
jwkawi
Jul 28, 2003 06:11 PM
1fitman
Jun 8, 2003 04:23 PM
yamaguy
Apr 19, 2003 10:32 PM
Mount
Apr 6, 2003 02:24 PM
