seating the bead
Old Jul 20, 1999 | 06:20 PM
robandkc's Avatar
i have just mounted 4 new fast trekkers and cannot seat the bead on any of them. Any tips on how to do it without going to the tire shop? i have tried tieing rope around the middle of the tire and tighting it but no luck on that. any tips would be greatly appreciated thanks alot----rob hammond
Old Jul 20, 1999 | 10:41 PM
EXtreme's Avatar
Rob,
the best thing to do is spend five bucks at the local shop and get them done quick and easy. If thats not your style, then use a ratchet strap around the tire to queeze the beads into position. If you aint got an air compressor, forget it! Much quick air is a must. Vasoline will seal any small leaks around the bead until it seats, but I don't reccomend that with only 6-8 lbs pressure...might cost you later.
Steve Small, 00' 400ex, 00' 325 Trail Boss for the Mrs.
Old Jul 21, 1999 | 01:47 AM
Pasqualie's Avatar
I seat the tires on my atv using the tire soap that tire shops use. It is thick, and slick. Coat the tire beads with the soap, and push the tire onto the side of the rim that has the longest taper. Clip the air hose on the valve steem and gently pull the tire up toward the side that is not touching the rim. Another trick is to use a second air hose with a blow nozzle attached. As you are puting air in the steem, blow air between the rim and the bead. It always works for me. Hope this helps. Dave
Old Jul 21, 1999 | 07:28 PM
robandkc's Avatar
thanks for the suggestions guys bu i went to a friend of my dads who has been a mechanic for like 25 years and he did it for us---for any of you do-it-yourselfers like me remove the inner valve stem to get more air in to seat the bead.you need a special tool to do it but id bet you all have one. thanks alot.
Robert Hammond---and one BAD Suzuki lt 125 '95 Blaster RLH151@Aol.Com
Old Jul 21, 1999 | 10:12 PM
EXtreme's Avatar
smart move!
Old Jul 31, 1999 | 10:43 PM
motorman's Avatar
a trick used by circle track dirt racers to mount wide tires on wide rims is to spray a little ether into the tire and throw a match at it. when the ether explodes it beads the tire. be carefull this is only to be done by professional under supervised conditions!
Old Aug 2, 1999 | 05:28 PM
philzie's Avatar
I watched my father-in-law do that with Acetalyne torch, on a tire for my van. Yes, it was freaky when the tire bounced off the floor. He claims to have done it to skidder tires too! But, he says you have to put real air in them before the exploded air shrinks, because it will suck the bead right back off the rim.
phil
badgerboy1
Sep 26, 2017 06:11 PM
Whitelx1
Oct 2, 2015 10:55 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
