good tires for a scrambler
Old Aug 20, 1999 | 11:00 AM
whisky's Avatar
i ride in some mud nothing real deep about over the foot brake i do alot of trail riding and i ride in a old stripe mine and i climb shale hills that are pretty loose i need front and back all help will be apperitated
99 500 scrambler with hotseat pipe and clutch dg bumper soon to have pistons and air box mod 93 yamaha t-wolve with a broken taillight soon to be fixed tailight is now fixed now need to fix headlight
Old Aug 20, 1999 | 12:17 PM
myscrambler's Avatar
Whiskey, This would be a tough question but the more I look for the right size tires the less of a choice I find. I am about to buy new tires and rims on my 99Scrambler500 too plus the dg front bumper and clutch kit. The only ones that look like they will work is these: if you want a matching set then look at the 22x11x10 Sur Traks for the back and the 23x8x11 Sur Traks on the front. The next set would be the Bearclaws 22x12x10 on the rear and the 23x8x11 on the front. If you want to mix and match sets then you will probably have to go with either of the two front 23x8x11 tires I mentioned above (BTW these are the only 23 inch tires I can find for the front that would be good on a 4x4) Mud shark makes a 23 front but not a 22 rear and of course you could get the titans but those come on it stock. If you get the 23s on the front you could go with 22 inch blackwaters, realtors, or mudmachines on he rear. I am going to get the bearclaws just for the extra 1 inch width on the rear. 23x8x11 on the front and 22x12x10 on the rear. I think after looking at every tire combo made this might be the best one for the scrambler. Later, Steve
Old Aug 20, 1999 | 01:44 PM
whisky's Avatar
i though about the bearclaws but when i gas it with these stock tires it stands up and spin alot if i put them bearclaws on i probabley could not keep the front end down and this is not a joke. i probabley get the stock ones again they aint bad tires i seen how you said you are getting a clutch kit a would get a pipe also i just got one and it helps a lot it was a hotseat superheader you will probably have to wait a while a had to wait 3 weeks but they could me it was not ready it is ready now and it is a real good pipe it makes it a little louder you can ride wheelies really good even if you lean forward it cost $250 it is worth it well thanks for the info
Old Aug 22, 1999 | 01:06 AM
David Bean's Avatar
Hey Whiskey, where do you ride? I ride some old strip mines in the East Texas area.
David Bean
99 Scrambler 400
99 Warrior
Old Aug 22, 1999 | 01:35 PM
whisky's Avatar
i ride in ohio really little county in old stripe mines not very many hills but the ones that are out here are steep alot of mud holes we have 2 race tracks one still in the making
txkevin
Sep 21, 2015 02:02 PM
rcappie4
Jun 21, 2015 07:33 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
