?? Locking hub problem? Polaris Sportsman 400 - 2002
Old Nov 20, 2004 | 04:04 PM
canuckPT's Avatar
Default ?? Locking hub problem? Polaris Sportsman 400 - 2002
It's amazing what some hub fluid will do. I drained the old fluid (there wasn't much in it and it was pretty dirty) and filled them up (as much as I could put in each as I couldn't find anywhere just how much to put in) and the problem appears to be gone. Hallelujah!
Old Nov 20, 2004 | 04:39 PM
Vaquero's Avatar
To get the proper fill level you turn the hub so the fill plug is at the 2 o'clock position(I think) and the fluid level should be there.
Old Nov 20, 2004 | 05:09 PM
canuckPT's Avatar
Assuming that I've overfilled it - what would happen if I didn't drain the excess fluid as I filled them at the 12 o'clock position (I obviously can do so easily but I'm just curious).
Old Nov 20, 2004 | 11:53 PM
Vaquero's Avatar
the only thing I can think of would be the fluid expanding as it warm up and leaking past the seal.
skittero
35
Mar 1, 2019 12:39 AM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
May 27, 2015 11:15 AM
