DG Alloy Nerfs on a 400EX
Old Sep 11, 1999 | 11:43 PM
Mike Frey's Avatar
I just got a set of DG Alloy Nerfs and I'm wondering how I am supposed to thred the webbing. If any DG nerf owners are out there, can help me out. Thanks.
I also ordered Renthals in 400EX-bend. They look awesome. Can't wait to install them.
Old Sep 12, 1999 | 01:54 AM
hot_shoe_cv's Avatar
Mike, Having Graydons on my Warrior, I can tell you about them & hope the same holds true for DG. On Graydons there are a series of points which contain two slots.You insert each end of webbing into the inside corresponding slot, coming up thru from the bottom, then across to the other slot &down thru it from the top. The end piece should now be hanging free from underneath the outermost slot on each point. Now it is just a matter of adjusting each strap to the correct shape & slack. Be sure to leave enough slack to get your toe under the shifter easily. You don't want to have the webbing taut anyway. In the event you'd be up on the pegs & your foot comes off the peg, you want the nerfs to catch your foot and not to launch it into the air again like a trampoline
After all this I hope your DG's are rigged the same as Graydons.
THE AZ HARD PACKER,calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 09-11-1999).]
Valder
Nov 28, 2020 07:38 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
