Front sprocket removal...help!
Old Mar 27, 2005 | 01:32 PM
bholz's Avatar
Default Front sprocket removal...help!
I'm trying to get the front sprocket off of my sons Dinli Helix 90...Is this a reverse thread bold holding it on? How can I keep the sprocket from spinning?
Old Mar 29, 2005 | 05:10 PM
Boxhead's Avatar
You just need a long breaker bar, and the threads shouldn't be reverse. To keep the tires from rotating you will probably need a person or two to hold the tires/frame from rolling forward. If it's too tough with a 2ft long breaker bar still just give the end of the handle a whack or two with a rubber mallet or hammer, they need a impact to budge them sometimes.
Old Mar 31, 2005 | 10:15 PM
2strokegood89's Avatar
wi the chain still on use the rear brakes an then torque away
Old Apr 3, 2005 | 10:42 PM
SNOTROD15's Avatar
I have a 350 raptor and I was looking to change my sprockets because i find I go through the gears too quick!! There is no speed in the 1,2,3 gears!! I see that you went with 14T in the front and 40 on the back!! How do you like that!! Is there a big difference?
Old Apr 5, 2005 | 02:32 AM
Boxhead's Avatar
14/40 is good with a pipe and some mods. Whatever you do don't get renthal fronts, they wear out quick even with the chain slack and allignment good.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
