Help with warn 424 Select
Old Jun 1, 2005 | 05:02 PM
Bradcue99's Avatar
Default Warn 424 Select
Need help with warn 424 select. I can pull the **** to disengage but as soon as I let go it pulls back in. I have tried to adjust the cable but it does'nt help. Any help would be great.
Old Jun 2, 2005 | 01:14 PM
pat89's Avatar
Default Help with warn 424 Select
It sounds like you may have a bind somewhere. Make sure your cable is as kink-free as possible. Are the two ball bearings in the **** assembly sticking? If so, this may be keeping the **** from locking in place. Beware that these two bearings have a tendancy to drop out upon disassembly so be careful. If their sticking spray some silicone lubricant and lightly press them down with a pair of needle nose pliers until they free up.
Old Jun 7, 2005 | 04:58 PM
LittleBill's Avatar
read my post in the honda forum about, i know its ur problem
Jeff Roper
Feb 1, 2022 11:48 AM
panicmanic
Sep 28, 2015 12:59 PM
carid
Sep 14, 2015 03:40 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
