changing tires
Old Nov 17, 2000 | 03:22 PM
like2wheel's Avatar
I get the Harbor Freight catalog,& I've never seen what you are describing.It sounds like a good deal. Do you have the item #?
Old Nov 18, 2000 | 01:58 PM
ridzhard's Avatar
Here is the numbers that are on the box. sku# p41347. I think that is the number they will need but there is also p.o.25474550 and c/no. 200 good luck.
Old Nov 18, 2000 | 10:06 PM
WEETOOTS's Avatar
Like2wheel,
My current catalog has the bead breaker on pg. 76, under "shop tools". They also show a nice ATV lift, 1250 lb capacity for $129... it is on the next to last page. Item #40381-3AMA
weetoots
Old Nov 20, 2000 | 11:44 PM
like2wheel's Avatar
I found it by your sku #. It says it works with 12-16.5" wheels.See any reason why it wouldn't work with smaller wheels?
Old Nov 21, 2000 | 12:48 AM
  #15
ridzhard's Avatar
This breaker relies on a "wedge" that goes on the inside of the rim, and two "hooks" that go on the outside of the rim. The blade is in between the two hooks and a bolt pushes the blade down. The setup is designed for larger rims, but with some creativity, you can make it work for the atv rims. Remember that you only need to push the bead down in one spot, then lube up the tire and rim, then use your body weight to work the rest of the bead off. (jump up and down on the tire. If anybody wants a demonstration, you are welcome to bring your tires to my garage and I will show you how to do it. Heck, bring your atv and we will ride too.
Bratman2
Aug 6, 2022 01:42 AM
Ean
Aug 28, 2015 09:39 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
