Kodiak 450 - Front left boot replacement HELP !!
Hello,
Looking for some help!!! I need to replace the boot on my front left velocity joint. The one that needs to be replace is the one closes to the left steering knuckle. I have taken it all apart, but I don't know how the new boot will fit over the hub with the bearing in it. Can someone please help me out!!!
Thanks in advance for you help !!
Ed
Ed
haven't done a Yamaha (done a dozen Arctic Cat's though) but I would speculate you have to pull the axle from the diff and disassemble the axle from the inside out, boot will slide off once you get the inner CV joint disassembled or removed from the shaft.
Rooky
10
Jun 23, 2015 09:35 PM
