kenda bear claw
Old Jun 1, 2007 | 12:52 PM
ctateusa1's Avatar
Default kenda bear claw
Yhea I can pull up the hills and rocks around here without any problem. Only in really deep mud could I see any problems(but that goes with 2wd you know)
The only time I have even gotten close to stuck was in loose creek gravel that it wanted to dig into the gravel.
I like the claws though cause they give great traction
Old Jun 1, 2007 | 01:13 PM
check's Avatar
Never make a decision before you have to, always have a Plan B, and don't tell me it's not possible!
I'll do another comparison this weekend, perhaps switching between the Bear Claws and the Mudlites on the same ATV. The Mudlites on both our 50 and 90 have performed admirably in the mud so far, but in order to really compare apples to apples I should take the Bear Claws off of our 250 and put on the Mudlites, and then run thru the same mudholes again. (This I can do easily because all of the tires are on 4-110 rims, meaning I don't have to mount and dismount the tries - just the rims.)
My guess, however, is that the Mudlites will perform way better than the Bear Claws when it comes to slogging through a slippery mud hole.
Old Jun 1, 2007 | 03:42 PM
buckaroo50's Avatar
If both are the sames size and tread depth I say it will be pretty close and could go either way. Since you picked Mudlites, I'll say the Bearclaws will do better.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
