Is BIGGER better????
Old Nov 20, 2007 | 05:23 PM
Stones's Avatar
Default Is BIGGER better????
I bought a 08 750 brute, i asked when i bought it about oversized tires. The dealer said i cold go with 29.5 outlaws and he would still cover me. Bought 26" xtrs instead. Yall should ask your dealer to make sure they wont cover you. personaly i think some machines would be downright unsafe with stock tires on. I'd hate to try my 750 wit h the stock tires i cant get traction under 10 mph woth oversized mud tires on.
Old Nov 28, 2007 | 02:52 AM
GrnXnham's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ctateusa1
up to a point, bigger is better on a utility or anywhere you need clearance. But you do drop in power, due to effectivly changing the gear ration of the quad 50mph drops to 45 mph. but you gain an inch in clearance.</end quote></div>
Actually, it's the opposite. Bigger tires decrease acceleration but INCREASE your top speed.
If you increase your tire size by 10%, your top speed will increase by 10% but your acceleration decreases.
So when you go with bigger and bigger tires your quad will get more and more sluggish but once you finally get up to your top speed, it will be a higher top speed.
Look at it this way:
A bigger tire travels further with each rotation, right? The length of the circumference of a larger tire is greater. So each time the tire makes one revolution with a bigger tire, the quad travels further--in other words, an increase in your top speed.
Irishman301
Sep 23, 2015 01:47 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Logan Collins
Sep 5, 2015 08:03 PM
