Need Help With Grizzly Slipping
Old Dec 19, 2007 | 11:42 PM
ctateusa1's Avatar
Default Need Help With Grizzly Slipping
Yhea the 8 rollers are in the sheave(spider?). The grease is actually just packed into the primary clutch pack (as I call it)[img]i/expressions/face-icon-small-wink.gif[/img] with the 8 rollers. They just sit inside the grease which provides them with the lube for rolling up and down.
In a tub of grizz grease there is suspossed to be 3-4 packings and on my first packing I put way too much in and it slung the excess out, which then had to be cleaned off of the belt and sheaves(primary and secondary, I refer to the back of the primary clutch pack as the front half of the primary sheeve, and the back half is the front of the primary that has all 5 of the small springs in it)
Old Dec 20, 2007 | 03:38 PM
hondabuster's Avatar
Actually the one lb tub does two packings. Yamaha recommends one ounce per roller. Theres supposed to be 8 ounces in there when done. If the grease comes out, check the o ring, and make sure it didnt get pinched, or is missing.
Old Dec 20, 2007 | 04:14 PM
ctateusa1's Avatar
no I know I just had too much in there because my oring is good and there, it just was so full that it slug out of the center cover in mine.
Jeff Roper
Feb 1, 2022 11:48 AM
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
