Need Help With Grizzly Slipping
All of sudden my 06 grizzly started slipping when the transmission shifts to the higher gear. This happens in either range. All the fuids have been regularly checked and changed.
Can anyone give a suggestion. Is something out of adjustment or is a clutch bad?
yamaha must publish the minimum belt width. if it is not in your manual, call a dealer and ask. I recommend a Yamaha shop manual. There are a few other things that can cause what you are talking about, but that is where I would start. The belt will slip if it is thin. Make sure your buttons and rollers look OK while you're in there. The clutches (any of the three (wet, primary, or secondary) can cause what you are talking about, but I wouldn't suspect them yet.
it's more than just checking the belt width. look for glazing and other damage, but that is a good place to start. Check the condition of the sheaves and look for contamination as well. Good luck. I just don't suspect you would have clutch trouble unless you have a ton of miles on it.
