1998 Grizzly 600 4x4 Slipping need help
I have a 1998 Yamaha Grizzly 600 4x4, it is not transfering but about 50% of the power to the wheels in 2 or 4 wheel drive. I have pulled the cover and the belt is 1 1/4 inches wide and looks good. it also meets the width from factory specs. So I am left scratching my head with this one. I was sure it would be the drive belt.
Can anyone help with this?
WHAT I DO IS DRIVE IT WITH THE COVER OFF SEE IF THE PRIMARY+SECONDARY MOVE CORRECTLY+RIDE THE BELT UP WITH OUT BACKING OFF UNDER ACCELERATION,BE CAREFUL,KEEP YOUR LEG FAR AWAY+WEAR SAFETY EQUIPTMENT.TRY NOT TO GET THINGS DIRTY.I WOULD FIRST SEE IF THERE IS ANY CONTAMINATES.
i was a yamaha technician and have see this before, it will probably be the "sprag type" clutch in behind the primary, remove primary, a tin cover behind that, then remove the cover primary shaft comes though and you will find the "sprag type clutch" as yamaha calls it. last time i did one could not buy the clutch ears seperate had to buy whole unit and was about 350 if memory serves me. hope that helps ya.
hey i just joined because i saw a tech answering here. i have a 2000 grizzly 600 4x4 thats making a scrubbing sound from the right side at the clutch . the atv runs great no problems other than sounds bad ,how do i fix before something major tares up
Jeff Roper
02-01-2022 11:48 AM
TLC
Utility ATVs
09-16-2015 01:41 PM
