Need Tire Help
Need Tire Help
I just bought a used 2002 Honda Foreman. The tires are bad and I was wanting to replace them inexpensively. I have located some slightly used tires at a local dealer. The fronts are kenda Bearclaws, and the rears are Maxxis Rubicons. The Bearclaws are listed as 24.3" in diameter, and the Rubicon's are listed as 25" in diameter. If I had a 2wd I wouldn't worry about the difference, should I be concerned about putting these on a 4x4 with slighly different diameters?
Thanks!
Thanks!
Need Tire Help
its not a big diff, but i wouldn't do it!! If you decide to, maybe let more air out of the larger and inflate the smaller one a little more and dont use 4x4 unless the front is able to spin freely in the mud.. For me its worth buy the right size and having that piece of mind that its not doing any damage.
09-30-2015 01:37 AM
