will a size 22-11-9 fit a size 22-10-9 tire/rim
Old Aug 18, 2008 | 04:35 PM
pacman_091's Avatar
Default will a size 22-11-9 fit a size 22-10-9 tire/rim
i cant seem to get the answer anywhere else...
Old Aug 18, 2008 | 05:29 PM
It think it should. The first number is the diameter, the second is the tire width and the third is the rim width. It should fit. You might want to call your local dealer for a definite answer.
Old Aug 18, 2008 | 05:59 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
First number is tire diameter (height), and the second number is tire width.
The most important number is the third....it is rim diameter (not "width" as stated above), and while you can fudge +/- a few inches on the other two numbers, you can't fudge at all on the rim diameter.
So yes, it will fit the rim. Will it be a "better" tire....who knows? I like my tires wide, and it will be an inch narrower than the other one.
Old Aug 18, 2008 | 06:10 PM
Thanks for clearing that up. I hadn't done anything with ATV tires in a long time and have forgotten what's what.
Old Aug 18, 2008 | 06:35 PM
pacman_091's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pacman_091
i cant seem to get the answer anywhere else...</end quote></div>
thnx you guys..
Old Aug 19, 2008 | 03:34 AM
user493's Avatar
Moto Psycho
The wheel will only have 2 dimensions, not 3 like the tires. Several different diameter tires will fit on one size wheel. The wheel is probably a 9"x8" or 9"x9". You could measure the width while the tire is off to be sure. The front wheels are probably skinnier, like 9"x5" or 9"x6". But everyone is right that an 11" wide tire will fit a rim that's made for a 10" tire. You can put wider, narrower, taller, or shorter tires on, as long as the wheel diameter is right and you don't change the width very much.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
