front brakes on recon
Old Nov 17, 2008 | 06:12 PM
pacman_091's Avatar
Default front brakes on recon
my brakes have WAY too much play on them, is their any way to tighten them up or would i have to go out and buy new disks??
Old Nov 17, 2008 | 07:41 PM
hondarider94's Avatar
i wouldnt mess with them... do they not work? on my recon the front brakes get filled with mud and glaze over and dont work!! once u hit water/mud there toast!
Old Nov 17, 2008 | 07:50 PM
swampyjunior's Avatar
My daughters 2001 recon has drum front brakes and there is a little plug you can remove on the outside of the drum. After removing the plug if you look in the hole and turn the tire (you need the tire off the ground for this) you will see a ratchet like adjuster that if you turn it will tighten the brakes up a bit. I think it is supposed to automatically adjust when you apply the brakes after backing up like automobiles do.
The brake pads can adjust all the way out until there is absolutely no pad left. So as long as there is brake pad left you can adjust them.
If it is has disk brakes on the fron you might check you wheel bearings. When the wheel bearings go out on a disk brake tire the wobbling tire pushes the brake pads out so that they have to travel farther when you apply them. This causes you to have to pump the brakes to get them to work.
In either case, it is an easy fix.
Swampy
Reactant
Mar 30, 2022 02:08 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
MNatv89
Jul 7, 2015 11:36 AM
