DESERT RIDING?? RIM SIZE???
9" will give you more sidewall and more cush, for a more comfortable and forgiving ride. Might feel a little mushy in hard turns, as the sidewall gives.
10" builds a lighter wheel, because rim is lighter than tire (less sidewall). Ride will be a little more harsh, seeing you don't get the cush of the taller sidewall.
But frankly....most folks could never tell the difference between the two!
My choice is ITP Baja 9X9" rims with reinforcement rings, with Holeshot XC tires (or XCT's when I need max ground clearance). Best combination I have found after searching and trying many different rims and tires for years.
Hankey Pankey
26
10-18-2020 03:50 PM
Frisky2050
04-09-2020 11:19 AM
