11 in wide tires on a 6 in rim
With a 6" rim, the 11" tire would bulge out pretty bad in the middle at normal inflation psi, you would wear the middle bald,or you would have to run pressure so low, the tire would be almost flat. Plus, I doubt an 11" tire would allow you to turn sharp,probably rub pretty bad.
